#!/bin/bash
### BEGIN INIT INFO
# Provides:          hobot
# Required-Start:    $all
# Required-Stop:
# Default-Start:     2 3 4 5
# Default-Stop:
# Short-Description: load wifi driver
### END INIT INFO
do_load_wifi()
	som_name=$(cat /sys/class/boardinfo/soc_name)
	if [ ${som_name} == '5' ];then
		modprobe bcmdhd
	elif [ ${som_name} == '6' ];then
		modprobe 8723ds
	elif [ ${som_name} == '8' ];then
		modprobe 8821cs
		config_file="/boot/config.txt"
		antenna_option="wifi_antenna"
		if [ -f "$config_file" ]; then
			antenna_value=$(grep -E "^$antenna_option=" "$config_file" | cut -d= -f2)
			if [ -n "$antenna_value" ]; then
				if [ "$antenna_value" = "cable" ]; then
					/bin/switch_antenna cable
				elif [ "$antenna_value" = "trace" ]; then
					/bin/switch_antenna trace
				else
					echo "Unrecognized value for $antenna_option: $antenna_value"
				fi
			else
			fi
		else
		fi
	fi
case "$1" in
	start)
		do_load_wifi
		exit 0
		echo "Usage: $0 start"
		exit 0
esac
